Rday,
Well I have a couple Ideas LISP, Attribute Text using X's and O's (Example;
JP5:Attribute), and nesting blocks. John had a pretty good Idea but it all
depends on how many dip switches you have. One other suggestion you want to
consider is making the Dip Switch itself a separate block with different
variations. Then you could and it the base block with refedit after
inserting it into the drawing. I don't know of any real intuitive way to do
this besides lisp to this.
Joshua Verdin
Applications Engineer
MasterGraphics, Inc.
"rday" wrote in message
news:19225768.1087570332696.JavaMail.jive@jiveforum1.autodesk.com...
> I have a block of a servo drive that contains a bank of 10 dip switches.
When this block is inserted I would like it to prompt for the position
(0 -1) of these and then display them on the block. Is this possible? Has
anyone done this?
> Thanks in advance,
> Robert
