AutoCAD Electrical Forum
Din rail insertion
2 REPLIES 2
rkinsey
423 Views, 2 Replies
Din rail insertion
Is there a lisp program or any other way to insert din rail between two components? A gentleman I used to work with had a din rail tool button - you picked a point on the first component and draged to a point on the second component. The din rail was inserted. This wasn't an "intelligent" din rail, but all I need is a way to insert din rail - not to capture it on a BOM.
Richard
2 REPLIES 2
dougmcalexander
in reply to: rkinsey
You ca insert intelligent DIN rail using the DIN rail/Wireway tool on the panel layout menu. If you wan't the DIN rail to be dumb lines, just use the Special Explode command.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in AutoCAD Electrical training and implementation support
Phone and Web-based Support Plans Available
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please Accept as Solution if I helped you. Likes are also much appreciated.
Not sure, but if you want to have non intelligent din rail, you can create din rail as AutoCAD dinamic block...
Regards
”Boost
