AutoCAD Electrical Forum
Din rail insertion
2 REPLIES 2
rkinsey
421 Views, 2 Replies
Din rail insertion
Is there a lisp program or any other way to insert din rail between two components? A gentleman I used to work with had a din rail tool button - you picked a point on the first component and draged to a point on the second component. The din rail was inserted. This wasn't an "intelligent" din rail, but all I need is a way to insert din rail - not to capture it on a BOM.
Richard
2 REPLIES 2
dougmcalexander
in reply to: rkinsey
You ca insert intelligent DIN rail using the DIN rail/Wireway tool on the panel layout menu. If you wan't the DIN rail to be dumb lines, just use the Special Explode command.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in AutoCAD Electrical training and implementation support
Phone and Web-based Support Plans Available
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please Accept as Solution if I helped you. Likes are also much appreciated.
purvy
Not sure, but if you want to have non intelligent din rail, you can create din rail as AutoCAD dinamic block...
Regards
”Boost
