There is no option to define default values in the create new drawing
dialog. It would not make sense. As soon as you click OK to insert the new
drawing, AcadE prompts you if you want to apply the project default values.
I allow this when I have made a specific modification at project level, for
this project only, thus I do not want to make a permanent change to the
drawing template.
It almost sounds as if you have no drawing template with the AcadE defaults
already defined. To make the most of AcadE you should have a border
template (.dwt file) that has the WD_TB attribute for title block update
(set up using Title Block Setup tool). This WD_TB attribute is added by the
Title Block Setup and you must be at the level of the border drawing where
all title block attributes are visible. Once this is complete, save this
drawing as a .dwg. Next click QNEW or File>New and use the acad.dwt
template. It is blank. Insert the drawing you created earlier (do not
explode on insert) at coordinates 0,0,0. Next click the Drawing Properties
icon on the ACE toolbar and set your most common defaults. Optionally you
might also add some of the common wire types you use so they will already
exist when you use this template to start a new drawing. The wire spool
flyout has a Create/Edit Wire Type icon for this.
Finally save this drawing as a template file in the template folder by
clicking Save As and changing the file type to template (.dwt). This will
be the file that you point to in the second line of the Create New Drawing
dialog. Now when you start a new drawing you get the defaults
automatically. If you need to change one or two items for a specific
project, set this in project properties and apply project defaults on
insert.
wrote in message news:5730837@discussion.autodesk.com...
I'm not trying to be difficult here, but is the answer "no, you can't insert
any default values into the 'create new drawing dialog box'" ?
TH
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in
AutoCAD Electrical training and implementation support
Phone and
Web-based Support Plans AvailablePhone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please
Accept as Solution if I helped you.
Likes are also much appreciated.
