AutoCAD Electrical General
mthomas
Message 1 of 5 (526 Views)
Default Catalog?
526 Views, 4 Replies
12-14-2011 08:51 AM
When we place a component from the catalog into our drawings it defaults on the AB catalog, which is also the largest. Is there any way to change this default?
Mike
Mike Thomas
Valued Contributor
Message 2 of 5 (518 Views)
Re: Default Catalog?
12-14-2011 12:16 PM in reply to: mthomas
If you open the default catalog in access then open the _LISTBOX_DEF table this defines the presets for when you click look up.
Message 3 of 5 (517 Views)
12-14-2011 12:20 PM in reply to: mthomas
The choice of default vendor is set in the _LISTBOX_DEF table of the default_cat.mdb file.  The program is delivered with some defaults just so it functions.  The idea is for us to change as needed to suit our needs.  See attached screen capture.
Note: This setting can be over-ruled by Block Name filtering, if a catalog record contains an entry in its WDBLKNAM field that pushes a select list of part numbers based upon the symbol block name.  The WDBLKNAM entry does not need to include the first letter "H" or "V" in the symbol name.  See attached screen capture.
Doug McAlexander
Independent Consultant/Instructor/Mentor specializing in AutoCAD Electrical, ecscad, and promis-e implementation
Web site: www.ECADConsultant.com
Phone: (770) 841-8009
Please Accept as Solution if I helped you. Kudos are also much appreciated.
mthomas
Message 4 of 5 (473 Views)
12-16-2011 05:50 AM in reply to: dougmcalexander
This worked, not as easy as I thought it would be, but really like the flexibity it provides.
Mike
Mike Thomas
Distinguished Contributor
Justin2012
Message 5 of 5 (305 Views)
12-20-2012 11:11 AM in reply to: mthomas
If I want the LISTBOX on my SECONDARY CATALOG to show all the components and not start with a particular mfg or etc how should I do it? Again, just the seconadry catalog
You are not logged in.
Manufacturing Community
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
