AutoCAD Electrical Forum
Default Catalog?
4 REPLIES 4
mthomas
912 Views, 4 Replies
Default Catalog?
When we place a component from the catalog into our drawings it defaults on the AB catalog, which is also the largest. Is there any way to change this default?
Mike
Mike Thomas
4 REPLIES 4
in reply to: mthomas
If you open the default catalog in access then open the _LISTBOX_DEF table this defines the presets for when you click look up.
dougmcalexander
The choice of default vendor is set in the _LISTBOX_DEF table of the default_cat.mdb file.  The program is delivered with some defaults just so it functions.  The idea is for us to change as needed to suit our needs.  See attached screen capture.
Note: This setting can be over-ruled by Block Name filtering, if a catalog record contains an entry in its WDBLKNAM field that pushes a select list of part numbers based upon the symbol block name.  The WDBLKNAM entry does not need to include the first letter "H" or "V" in the symbol name.  See attached screen capture.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in AutoCAD Electrical training and implementation support
Phone and Web-based Support Plans Available
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please Accept as Solution if I helped you. Likes are also much appreciated.
mthomas
in reply to: dougmcalexander
This worked, not as easy as I thought it would be, but really like the flexibity it provides.
Mike
Mike Thomas
If I want the LISTBOX on my SECONDARY CATALOG to show all the components and not start with a particular mfg or etc how should I do it? Again, just the seconadry catalog
”Boost
