Peter,
After looking at the drawing you sent, I think the issue is that there are
two X?LINK attributes right on top of each other. I will log this issue but
for now you might try moving the X?LINK attributes away from each other.
Pat Murnen
wrote in message news:5728047@discussion.autodesk.com...
Please log this issue.
If you remove a component which has Dashed Link Lines these lines are not
removed.
For example:
Motor starter 3 Pole
Containing block VMS21P
or
Current Limit/Thermal
Containing blocks VCB11THI and VCB21THI
Using AE2008 + SP1
Peter
