Hi! DIN again (it's popular now).
I need to make attributes DESC1-DESC3, Count and Unit visible. Yes, I can fill they and place in report, but there aren't listed attributes in "Edit atribute" window. There are only 3: P_TAG1, RATING1, RATING3.
How can I make they visible? I can't find a block too.
And the same issue with Enclosures.
Thank you!
Solved by rhesusminus. Go to Solution.
i.
If the bolck doesn't have the required attributes, the data is stored in XDATA on the symbol.
There is a tool convert XDATA to Attrbiutes, namely "Make Xdata Visible".
Have a look at this function:
And I've found the DIN-file.
C:\documents and settings\all users\documents\autodesk\acade 2013\libs\panel\wd_ptag_addattr_comp.dwg (for 64 XP).
Now I can simply add my attributes there.
