Post a sample of your custom cable marker symbols. What exactly did you change? Did you add anything? Did you follow the block naming conventions for cable markers?
What do you mean by a different name? The block name is HW_01 or HW_02.
When I was using the symbol builder to create the cable marker block there was no "cable" option so I had to choose "generic". The default name given to the block was HDV1_001, which I changed to HW_01 before saving.
I didn't see your attachments the first time. The underscore is what is causing your problem. Cable markers should be HW01 & HW02 rather than HW_01 & HW_02.
Have a look at this for help on naming conventions. Cable markers happen to be the first thing covered.
