Hi, Pat,
Yep, the cross-referecing between components works fine, Surfing works fine too, but Cross-Reference Check tool doesn't work. Now I'm using ACE 2009 Service Pack 1, but this problem with Check tool I had on previous version (ACE 2008 Service Pack 1) too.
ACE Help says:
"Using the Cross-Reference Check tool (Components Cross-Reference Cross-Reference Check), AutoCAD Electrical first extracts a complete list of components from the project drawing set. Then it prompts you to select a component to check. AutoCAD Electrical reads the component's tag, finds all associated components, and lists them in a dialog..."
Mhm, maybe I'm doing something wrong or don't understand something...
Thanks for replay, Pat.
purvy
