Hi Carl,
The key to making this work automatically is naming your parent and child
symbol the same except for the 4th char. The parent needs to have a "1" as
the 4th character of the block name and the child have a "2" as this 4th
character. So, if you create a parent symbol called "HPH1XYZ.dwg", then you
need to name your child symbol "HPH2XYZ.dwg" for the multi-pole command to
be able to find and insert the child poles after the parent pole.
Does this make sense? Am I understanding the question? If not, please send
me what you've tried to make work and I'll take a look. You can send
privately if you'd like to nate.holt@autodesk.com.
thanks,
Nate.
wrote in message news:5038892@discussion.autodesk.com...
The second of your options. One parent two childs that automatically adjust
to fit into a three phase bus.
Carl
