So I have been tasked to create an operator's station with four pushbuttons within an enclosure, then have the BOM display the parent component as well as the child components as subassemblies.
I learned through the forums that you cannot have a subassembly from the PB table attached to a parent component from the EN table, if I understood correctly. This doesn't seem very sensical to me.
Q1: Shouldn't there be a system in place to allow an enclosure to have subassemblies attached to it from different tables? The multiple catalog method is the next best method that I know of, and this never saves the information to the component for later use.
Right now, I have managed to successfully attach the subassembly pushbuttons to the enclosure using the Multiple Catalog method. Because the layout still has the enclosure footprint, along with the four pushbutton footprints, the BOM displays each pushbutton as separate entities AND the enclosure with the pushbutton sub assemblies.
Q2: Is there a way to create a footprint of this enclosure depicted with the various pushbuttons, drop it into the drawing, and then have the BOM still display the subassemblies underneath the parent component?
The components I'm using are as follows:
Parent: E4PB (EN)
Subs: 800T-FX6A1 (PB)
800T-D9A (PB)
800T-QA24W (PB)
800T-A1A (PB)
I've attached a screen shot of the current BOM display where I used the Mutliple Catalog method.
Thanks for your time.
I've come across the same problem when trying to link a fuse in the FU table to a M205 teminal fuse holder in the TRMS table. I got around it by adding the required fuseholder components to the FU table as sub components.
With your problem, I would insert the footprint of the enclosure and then add the footprints for the pushbuttons as seperate components on top of the footprint of the enclosure.
You end up with 5 footprints instead of one, but the footprints for the PB's can be linked to the PB block in the schematic as normal.
Regards Brad
Brad Coleman, Electrical Draftsman
