I have been using the PLC Database editor to create customized PLC I/O modules that are tweaked to our liking based off the standard ones in the database.
On thing I cannot figure out how to do is to make these Child rather than Parent symbols. I have a simple power supply symbol that I have created that I have as a Parent which will hold the Catalog/BOM info. I want to have these I/O modules be children so that inherit the same TAG number and they do not show up on the BOM as a seperate device These are "Expandable" brick style PLCs I am dealing with that have built in I/O (Compact Logix L16/L18 series).
I know you can do this with the individual I/O point symbols, but I don't want to use those.
I have read through the Forums and it looks to me like this is not possible right now with Parametric PLC modules.
I would appreciate any help to point me in the right direction.
This could be done manually, the key is in the block names and attributes.
However, for convenience, I would suggest creating a parametric PLC model with the power supply terminals at the top of the list. Then add a break after the power supply terminals. The parent and child module could placed then manually cut and paste the child section of the PLC to the desired page.
Also, I don't recommend this, but ACADE may be able to handle two Top PLC Modules (with the line1, line2, descriptions, part#, manufacture, etc.). Include one Top Module at the start of the power supply terminals and a second at the start of the PLC I/O terminals. This may allow PLC descriptions and info. to be included on the both the parent and child PLC symbol. However, I have a feeling that all of the child descriptions may not auto-update if the parent descriptions are changed, time permiting this may definitely be worth a try.
