I passed your question on to folks much more knowledgable on this... here's
what came back:
Resetting the profile "fixes" the issue.. I've gotten a couple calls on this
issue. It happens, more often on laptops, where they go from a dual-monitor
setup down to a single monitor.
They may have to remove the CUIs and do a repair from the CD.
wrote in message news:4960522@discussion.autodesk.com...
Thanks for the help.
Yes it occurs with any drawing.
I tried AutoCAD Audit, but it didn't find any errors and the problem still
exists.
Command: AUDIT
Fix any errors detected? [Yes/No] : y
3 Blocks audited
Pass 1 233 objects audited
Pass 2 233 objects audited
Pass 3 300 objects audited
Total errors found 0 fixed 0
If I select the "Layer Properties Manager" toolbar button, it locks up and
nothing appears on the command line. If I hit ESC, the following appears
Command: '_layer
If I right click on the toolbar and choose "Customize...", AutoCAD also
locks up and nothing appears on the command line. It won't clear on ESC for
this command, but does for ALT-F4. The following line then appears
Command: _.CUI
I haven't found any other toolbar items that won't work so far.
I don't know if this information provides any benefit in solving the
problem, but when I start AutoCAD, the following items appear on the Command
window.
Customization file loaded successfully. Customization Group: ACADE
Customization file loaded successfully. Customization Group: ELECTRICAL
Customization file loaded successfully. Customization Group: EXPRESS
Regenerating model.
Loading Electrical modules.....
Loader application completed
AutoCAD Express Tools Copyright © 2002-2004 Autodesk, Inc.
AutoCAD Electrical menu utilities loaded.
AutoCAD menu utilities loaded.
Command: COMMANDLINE
Command: TOOLPALETTES
