You will need to copy the library folder itself (i.e. JIC125, IEC2, etc.).
You will need to copy the image files for any new icons you created for the insert component menu. These are usually in the following path:
C:\Documents and Settings\yourname\Application Data\Autodesk\AutoCAD Electrical 2008\R17.1\enu\Support\Images
You will also need to copy the menu.dat file that you modified to add the new symbols to the icon menu (i.e. ACE_JIC_MENU.DAT). This will be in the following folder:
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in
AutoCAD Electrical training and implementation support
Phone and
Web-based Support Plans AvailablePhone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please
Accept as Solution if I helped you.
Likes are also much appreciated.
