I'm trying to make a copy of my design in Vault (ACADE & Vault Pro 2013) and I am getting this error which ends the process.
Any ideas what is causing this or how I should procede? This is the first indication I've seen that the WDP file needs repairing. Or is it telling me it can't repair the new copy? (Version 2) If so, what exactly is this telling me? (See attached image.)
Thanks.
Not sure how well Vault Copy Design works with Electrical projects. There is a Copy Design built into AcadE, however, which works very nicely.... and from there you can check the project into the Vault. Give that a shot?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
The WDP file extension is used by several different programs and vault may be looking for one of those due to the file extension default on the system Vault is installed on.
Here is something to get the IT department to try - On the system where vault is installed, set the default program for the WDP file extension to notepad. This will then set any WDP file to a simple text designation and may fix the problem.
A quick search brought up this list for the WDP file extension at this site http://filext.com/file-extension/WDP and shows just how often the extension has been used.
I've noticed that on some of the systems where I work, that the wdp project file shows up with an image icon while on others it shows as an unknown file icon. My system has it show with a text file icon as I have set it to that.
Regards Brad
Brad Coleman, Electrical Draftsman
Hi Joe,
Likely the file is Locked in a State.
Check to make sure its not in a "Released" State.
It is possible that the file is damaged, Try checking the file out and see if it has issue on check out.
if it has no issues there then it might be server side (it could need a Re-index, for the file to be "re-located")
If you haven't Already try applying the latest Service packs for the vault and for ACADE.
Let me know,
James
The copy design function for AcadE just isn't stable. I would reccommend to just use the Copy Project function inside AcadE, and check that project into vault.
