AutoCAD Electrical Forum
Converting Autocad Electrical to Eplan
4 REPLIES 4
12098 Views, 4 Replies
One of my customers has asked for their drawings to be supplied in Eplan format.  Is it possible, and if so, how do I convert a project / drawings to Eplan format???
4 REPLIES 4
The answer is NO.
dougmcalexander
EPlan is database-driven by its own proprietary database structure.  There is no conversion utility available to transfer from the open architecture of AutoCAD Electrical into the proprietary database structure of EPlan.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor
Specializing in AutoCAD Electrical Implementation Support
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
rhesusminus
You cannot export to eplan, but eplan can import DWG-files. However, the drawings will be "dumb" like paper drawings.
THL
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
Basically no, but standard layers can be converted to ePLAN layers, however the intelligence will be lost.  This article explains how to convert drawings from DWG/DXF to ePLAN, in the case it is inevitable (For example if a company or department has made the decision to switch tools).  In my opinion it is probably better to just redraw in a other tool.  However, here is the article in case it is relevant.
https://www.bengineer.se/solutions-losningar/dwg-dxf-converting-eplan
