AutoCAD Electrical Forum
Converted to «o» to «x» in the dialog box « Panel Components...»
3 REPLIES 3
galashkina
364 Views, 3 Replies
I start the Insert Component (Panel List) command.
In the dialog box « Panel Components...» in the left column displays the «x» and «o».
What command can be converted to «o» to «x»?
3 REPLIES 3
rhesusminus
in reply to: galashkina
If you press the HELP-button in this dialog, the help-file says:
"An "x" displays in left-hand column for any listed panel component tag that already has its schematic component inserted on the drawing and there is an exact match on catalog and manufacturer values between the two. An "o" displays if the tags match but there is mismatch on catalog and manufacturer values between the two."
Trond Hasse Lie
AutoCAD Electrical and EPLAN expert
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
galashkina
in reply to: rhesusminus
Can somehow update the database of the project to the "o" was transformed into an "x"?
rhesusminus
I don't belive you can do this amutomatically.
You'll have to go to the components marked "o", and make sure that the Manufacturer/Catalog data matches on both schematic and panel components.
Trond Hasse Lie
Ctrl Alt El
”Boost
