There is not an actual symbol conversion. AcadE comes with JIC, IEC, JIS,
GB, and AS libraries. The only symbols you will possibly need to convert
are custom symbols you created. The easiest way to do this is to use the
Special Explode tool, which will strip out the Promis-e attributes, and then
use Symbol Builder to insert the correct AcadE attributes. Then save as a
WBlock to a custom library folder.
wrote in message news:5985001@discussion.autodesk.com...
Good day gentlemen:
Our company is switching over from Promise to AE2008. We can convert
projects from promise to AE2008. How do we convert promise's symbol librarys
to AE2008 symbols? Thanks for all of the help!
Terry
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in
AutoCAD Electrical training and implementation support
Phone and
Web-based Support Plans AvailablePhone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please
Accept as Solution if I helped you.
Likes are also much appreciated.
