AutoCAD Electrical Forum
Component won't insert at correct location
2 REPLIES 2
mattheath
250 Views, 2 Replies
This is only happeneing in this drawing. I have succesfully insert this component before in other files.
The fuse inserts above and to the left of the insertion point that I pick. The insertion point point grip is at the correct location and the TAG is correct but everything else is wrong.
Is there a setting somewhere that is incorrect. I swear I did a save-as from another drawing to create this one and the other drawing is fine.
Matt Heath
2 REPLIES 2
mattheath
in reply to: mattheath
ACAD Electrical 2008 SP1
dougmcalexander
Try the Update block command under Swap/Update Block menu. It seems that
maybe somehow the block in your drawing was redefined. Update the block to
the original one from the symbol folder.
wrote in message news:5979794@discussion.autodesk.com...
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in AutoCAD Electrical training and implementation support
Phone and Web-based Support Plans Available
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please Accept as Solution if I helped you. Likes are also much appreciated.
”Boost
