Not able to understand. I tried by changing catalog values for some components but not getting reflected in its report(component report. CAn anyone explain me its use in detail.
Thanks for the reply. But there is no entry in the Component Report generated by this tool even if there is a change in the catalog database for the assigned part no of a component. As per my undersatnding, there should be an entry in the component report if a catalog value or a manufacturer is changed for a component having an assigned part no from the catalog database.
What are the entries that are reflected in the Component report generated frim this tool?
I am having a very similar issue. I am running windows 7 with Autocad Electrical 2018.
When I run the Component update from the Catalog. I have selected Item Only have tried overwrite and blank items only. Neither one will update the product and when the report is pulled up it is blank. Nothing has been updated.
Your question is a bit vague. Can you describe your exact issue? I'm not sure what you mean by selecting Item Only. That isn't an option from the Component Update From Catalog utility. The Component Update from Catalog simply replaces attribute values on selected components, in case you made a change to the record for that part number in the Catalog Database after the part was already assigned to components in a drawing. It has no affect on Item Number. The Resequence Item Numbers utility can update Item Number assignments.
Sorry about that. Either way Overwrite existing or Update blank items Only. I can not get it to work.
What version of AutoCAD Electrical are you using? Is it updated to the latest service pack? Are you certain that the catalog database you made changes to is the same one that your project is pointing to? You can check this in Project Settings. What report are you running, Component, BOM, etc.
It can be difficult to speculate on issues when I don't know your installation. Are you networked or operating autonomously? If operating autonomously, is your software installed at default file paths? Do you have a secondary catalog database assigned to the project?
The part number has a specific value in the catalog in the (TEXTVALUE coloumn) which is ITEM=DNO, When the item is first inserted, it does put DNO in the ITEM. But if you re sequence the items numbers it overwrites the item number, Which is why I thought the Component Update from catalog would work.
The Resequence Item Numbers utility writes to the ITEM attribute of any component symbol. It is designed to give you a quick and error-free way to assign item numbers alphabetically, according to manufacturer name. It will do so project-wide, in seconds. This allows you to sort your BOM by item number and still have it grouped by manufacturer. You can then use the same BOM to build the panel and to order the parts.
Anyone who decides to manually assign ITEM numbers, either by typing in, selecting NEXT available, or by writing a value to the ITEM attribute via the TEXTVALUE field of the Catalog Database record, should not use the Resequence Item Numbers tool. Again, the Resequence Item Numbers utility is there for those who prefer to leverage the automated capabilities of AutoCAD Electrical to save time and reduce human errors.
