Check you Drawing Properties. I'll bet they don't match project properties.
Run settings compare under the drawing properties fly-out menu. Drawing
Properties supersede project properties, so you can have specific drawings
set up differently. The settings compare will show you the differences
between project properties and drawing properties. Project properties can
override drawing properties when you add a drawing to a project and choose
to apply project defaults. You can also make all drawings in a project
match the project properties by selecting all drawings, right-clicking, and
applying project properties.
"Paul"
wrote in message
news:5940437@discussion.autodesk.com...
When I insert a new componet, the component is labled as PB1 instead of the
rung it is on ie PB102. Under Projcect Properties/Components I have
selected Line Reverence as teh Component Tag format, but I still get this
problem..any suggestions?
P
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in
AutoCAD Electrical training and implementation support
Phone and
Web-based Support Plans AvailablePhone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please
Accept as Solution if I helped you.
Likes are also much appreciated.
