AutoCAD Electrical Forum
Component Footprints
3 REPLIES 3
ltuk
407 Views, 3 Replies
Gents,
Is it possible to carry the wire numbers from a schematic part and show them on a component footprint? (If it is possible what attributes have to be inserted on the footprint?)
We have a fascia layout drawing for every panel requiring one and if possible would like to make it possible so that the wire numbers which go to the fascia, show on the appropriate pushbutton / lamp / selector switch.
Thanks for your continued help.
LTUK
3 REPLIES 3
in reply to: ltuk
You want to use the Wire Annotation of Panel Footprints feature. It can be
found on the Panel Layout menu or toolbar. If the footprints don't carry the
target attributes then mtext will be added.
If the panel footprint blocks carry certain target attributes, then these
will be updated with the wire information. Each wire connection attribute
definition (WIRENOxx) is tied to a terminal attribute definition (TERMxx)
via matching two digit suffix on each attribute tag pair. So the connection
to the TERM01 attribute on the schematic component will be shown on the
WIRENO01 attriubte on the panel footprint. Target attributes are:
WIRENO*
TERMDESC*
TERM*
WDEV*
WLAY*
You can get more information regarding this feature by selecting teh Help
buttons from the dialog once you select to run it.
Pat Murnen
wrote in message news:5474825@discussion.autodesk.com...
Gents,
LTUK
ltuk
in reply to: ltuk
test
testsubject
in reply to: ltuk
Ressurecting an old post because I found it very helpful.
One thing I want to add that was not apparent from the help file was that the TERMx value has to be on the footprint for the other added attributes to work. I initially added only the WIRENOx attribute to the footprint and it was not updating until I added the TERMx att. Since I do not want to have the TERMx info displayed, I just hid it in the footprint and everything works like a Charm.
Also the associated att has to exist in the schematic symbol; i.e. I wanted the wire number of a distribution block to appear on the footprint so I had to add WIRENO01 to the schematic symbol and TERM01 and WIRENO01 to the footprint symbol.
Thanks again Pat!!
Bob Hanrahan
Ace User since 1998
If this answered your question, please click on "Accept Solution"
”Boost
