When I update cross-references it will be different text size for the references. Some times 2.5 mm and some time 1.8mm.
How is determined the size of the references?
How can I ensure that there will always be the same font size?
/Johnny
If you use the same graphic style:
DESCRIPTION STYLE TYPE SIZE
contact number WD_IEC monotxt 1.8
contact "" acaderef 2.7
REF "" isocp2 2.7
In every drawing these styles must be the same, to ensure this make it the same in every DWT and do not edit these styles !
And make a script to change existing drawings.
