AutoCAD Electrical Forum
Component Cross Reference Display
4 REPLIES 4
Tee.Dee
546 Views, 4 Replies
Hey all,
I have a project with a bunch of relay coils on 1 drawing and a single contact for each coil on another drawing.
The problem I am having is getting the graphical component cross reference to display next to the coil.
I have tried doing  a "component cross reference" update, deleting the project mdb file, closing and reopening the project and also  a "swap/update block".
There are 2 coils on the drawing that are showing the graphical cross reference and they work fine, they also work if a copy them and rename them to one of the coils that isnt working but I dont want to have to do that for every one.
Any suggestions?
Thanks.
4 REPLIES 4
Icemanau
in reply to: Tee.Dee
Try editing the contacts that are not showing up. Do a PROJECT search and tie them dierectly to the coil.
That should fix your problem.
Regards Brad
Brad Coleman, Electrical Draftsman
Tee.Dee
Thanks Brad but I forgot to mention i have tried that to, it was actually how I had to link them in the first place but I have tried doing it again and still no luck
Tee.Dee
Just worked out a way to get it working, not ideal but the quickest way I can find that works.
Im using the swap/update block to swap each of the coils for another parent symbol (i chose a pushbutton), then swap the pushbuttons back to a coil symbol and run the cross reference update.
JMARSHALL1249
Could it be that the Installation / Location of the two sheets have different Default settings, hence they are unable to cross reference.
”Boost
