AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Component Balloon Leaders
1 REPLY 1
jdonaldson3
480 Views, 1 Reply
I need component balloons with multiple leaders like the regular AutoCAD multileader command? I found the previous question
http://forums.autodesk.com/t5/AutoCAD-Electrical/Panel-Balloon-Multi-Leader/m-p/2955890/highlight/tr...
But did not see an answer.
Jim
1 REPLY 1
jdonaldson3
in reply to: jdonaldson3
Further trial and error as shown me that I can start the Balloon command, select component, draw the leader and then escape (cancel ) out of the command draws just the leader on the correct layer and at the correct size. Then repeat as many times as required.
This is just a work around as it doesn't really draw a leader from the balloon. Just lines and a solid for the arrow head. Meaning you can have limited editing ability and if changes occur you really have to redraw the arrow.
Jim
”Boost
