It seems that I need professional help again. Well, I am trying to generate an Omron DRT2-MD32SL combo (16 Input & 16 Output) module via Spreadsheet to PLC I/O Utility. It should insert custom circuits instead of rungs. My problem is, it can not distinguish between input and output terminals so my in-line devices show up at the wrong spot.
All configuration files are in the attached zip file.
Thank you
