The Spreadsheet to PLC I/O Utility calculates the module offset depending on the IO Type. If it is a combo (input/output) or if it can not figure out the IO Type, it puts the module in the middle of input and output offsets. The PLC IO I am working with consist of 16 inputs and 16 outputs. The input ones come in the right ladder and the output ones in the left ladder. I want to have the wdio changed, so that the input offset value sets the input module offset and output offset value sets the output module offset. This means each module depending on the IO type, gets located depending on input or output offset value not the center calculation. I'm not an AutoLISP expert so I hope that somebody can help me with this. A sample drawing is attached.
Thank you
