When using "graphic" cross references, what determines the size of the text for coil component cross references. At first were too big so I switched to text style and the length was too long so I switched back to graphic. After the switch the size was acceptable.
Also, when there were more than 3 references for a coil, The Attribute size dialog would only work on the first 2 references, after that the cross reference changed to a string of characters that look like formating stuff. I would give you an example, but don't have one right now.
