AutoCAD Electrical Forum
Circuit Builder - Hiding Attributes
0 REPLIES 0
Message 1 of 1
Zypo88
321 Views, 0 Replies
Does anyone know if there is a way to hide some or all of the attributes on a marker inserted by the circuit builder?  I am trying to insert cable markers, but I don't need the cable number or "RATING1" values to show up on every single wire that goes to the cable.
I am using the Insert Symbol command to place the cable markers, I tried "multipole" but either it didn't like the shielded cable, or it had a problem with using two secondary markers.
Spreadsheet COMMAND_LIST values:
(c:ace_cb_insym #xyz nil "HW02_2T" #scl 8 nil)
(c:ace_cb_insym #xyz nil "HW02_2" #scl 8 nil)
Block MISC values are:
TAG2=@MOTOR_NUM@-1;RATING1=1-BLK
TAG2=@MOTOR_NUM@-2;RATING1=1-WHT
Thanks in advance.
0 REPLIES 0
”Boost
