You create new wire types through the Create/Edit Wire Type tool. It does
indeed look like a spreadsheet. You can assign the color that the wire will
be on screen as well from this dialog, even the line type. You can assign
wire types to lines by using a crossing (backwards) window and anything the
window touches will be selected. You can pick any segment of each wire you
want to assign to the particular layer but if they are close together, the
crossing window is better.
The wire numbering is independent of the wire type. You can wire number
anytime you wish. If you have a particular wire number format set in the
drawing properties, AcadE will assign wire numbers to the entire drawing by
simply clicking the Drawing-wide button. You can choose Project-wide and it
will assign wire numbers to all drawings in the project.
If you are not following standard wire numbering schemes, like line
referenced or sequential then yes, you must assign each wire number with the
Edit Wire Number tool. This is cumbersome but AcadE cannot know how you
want to number wires if you are not following a standard scheme. For
example, if you are using ladders, AcadE can be configured to assign the
wire number based upon the line or rung number where it is located. A wire
on rung 100 would be wire number 100. A second wire number on the same rung
would be 100A,or 100-1, etc. You can set up this syntax in the drawing
properties. But if you have to name wires according to the function of your
machine (i.e. RAM DRIVE LEFT 24V+) you will have to do it manually.
Now just in case you are referring to the optional labels that can appear
next to a wire depicting the type of wire, those are not wire numbers; those
are wire color/gauge labels. They are inserted using the Insert Wire
Color/Gauge Labels toll under the wire leaders fly-out menu. These are
inserted one wire at a time with no leader, with a leader that you place, or
with an automatic leader. If you use Automatic leader, you can select wires
in groups using the crossing window and AcadE will insert the labels itself.
If you don't like a location where it inserted, you can use the standard
AutoCAD Move command to move it around. The color/gauge labels are actually
dimension text so you can adjust them with regular Acad commands. You can
even type dimstyle at the command prompt and adjust the font and size.
wrote in message news:5951561@discussion.autodesk.com...
What I was looking for was a way to validate the wire number(name) is the
same as the layer name. I often start out w/other folks drawings, it would
be nice if the layername & wire number matched up.
Now what I have to do is create/ fill out the wire type spreadsheet. Next
make sure the lines(wires) are on the correct layer, then update the wire
name using the edit wire number.
I hope I'm doing this wrong, because there must be an easier way!
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in
AutoCAD Electrical training and implementation support
Phone and
Web-based Support Plans AvailablePhone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please
Accept as Solution if I helped you.
Likes are also much appreciated.
