fdna49
If you are needing to change the "%F" portion of the tag for the
customer, then you can create the file "wd_fam.dat". This file allows you
to have the "%F" portion of the device tags changed when the devices are
inserted without having to modify the blocks. You will create this file in
notepad, and save it in the same location as this specific project for this
customer. Also, after creating the file, you will need to restart AutoCAD
Electrical. Here is the format inside the file:
CR,K
PBLT,PB-LT
The entry before the comma is the existing tag (%F) value and after the
comma is what you want it changed to. Once this file is created and
Electrical has been restarted, when you run RETAG or insert a the components
their tag (%F) value will be changed automatically to what you have defined
in the wd_fam.dat file.
One other thing you may look at is the option to make the tags FIXED.
AutoCAD Electrical allows you to specify tag or wire number values as being
FIXED so that when you run the automated features for retagging or
renumbering the wire numbers, tags marked as fixed will not be modified.
You also may use the COPY PROJECT command before making these
modifications so that you will have a new project specific for this customer
and then can tag the items according to their needs.
I hope this helps!!
Jared Bunch
"testsubject" wrote in message
news:19454279.1095791806616.JavaMail.jive@jiveforum1.autodesk.com...
> Here is what I would do for each symbol in the drawing. Select each symbol
and right click with the mouse away from the symbol. Select Edit Attributes
and scroll down to the attribute Family. Change this to the prefix that you
want to use for the retag. Now when you run retag, it will use this prefix
for the retag instead of the original one.
