Testsubject
In addition to Rob's recommendation, you can also make a default file
rather than using the project specific. That file is setup the exact same
way, it is just named default_wdtitle.wdl. This file is generally kept in
the USER folder, but as long as it is in a location that AutoCAD Electrical
searches it should be found.
Jared Bunch
Technical Support Specialist
Autodesk, Inc
"RobStein" wrote in message
news:14969548.1084274973990.JavaMail.jive@jiveforum1.autodesk.com...
> Hi,
> You will need to create a file called ProjName_wdtitle.wdl and place it
in the directory where your project file is located. ProjName = Same name as
your project file. This file is a text file with a .wdl extension. within
this file you will create the following:
> LINE1=Description Line 1
> LINE2=Description Line 2
> LINE3=Description Line 3
> etc....
> Hope this helps
