AutoCAD Electrical Forum
Changing Defaults- JIC to IEC Standard
7 REPLIES 7
Message 1 of 8
5231 Views, 7 Replies
Mario says:
Subject: Changing Defaults- JIC to IEC Standard
Question: I am using Autocad2008 Electrical. I have installed all the
symbol libraries.But when I want to insert a component I am only shown the
symbols (for example 2 pole circuit breaker) according to the JIC standard.
How can I select and insert in the drawing a symbol from another standard
for example IEC? Can I change the default library from JIC standard to IEC
standard. That is when I select the Insert Component or Componet button the
IEC standard symbols are show.
Since I don't know electrical, I thought I'm pose the question for him on
his behalf on this forum.
Can you help?
_________________________
Bill DeShawn
bdeshawn@nospamsterling.net
http://my.sterling.net/~bdeshawn
7 REPLIES 7
Message 2 of 8
I found this answer:
When you install the software you choose which default standard but when you
choose your libraries to install you can install as many as you want. Then
for each project you define whether it is JIC or IEC by selecting the
Component Tagging options (can be applied to each drawing as this is a
drawing setting) and defining which library to use, i.e. JIC or IEC.
Pat Murnen
Thanks, Pat.
Bill DeShawn
"Bill DeShawn" wrote in message
news:5877231@discussion.autodesk.com...
Mario says:
Can you help?
Bill DeShawn
Message 3 of 8
Mario says:
Still having trouble:
First of all thanks a lot for your quick reply. I tried to do it but failed.
I selected Component Tagging but did not manage to find where I can pick
IEC. If it's not a problem can you walk me through the steps please.
THANKS
Bill DeShawn
news:5877202@discussion.autodesk.com...
Pat Murnen
Thanks, Pat.
Bill DeShawn
Mario says:
Can you help?
Bill DeShawn
Message 4 of 8
The project points to a particular library folder or series of folders. To
define this:
1. right-click on the project name in Project Manager
2. select Properties
3. select the Project Settings tab
4. expand the Schematic Libraries section
5. remove any folder names you do not want, for example, the c:\program
files....\jic125 and add the ones you want, for example, c:\program
files\....\iec2. The order the paths are listed are the order that AcadE
will search for a symbol on insertion. Use the buttons at the right to
Delete, Add, Browse.
To select IEC style tagging. This can be done on a per-drawing basis or as a
proejct setting. If done as a project setting it must be applied to each
drawing as shown below. Remember, when Project Settings are applied to
drawings, it is all settings not just specific ones.
3. Select the Components tab.
4. In the Component TAG Options section, select Combined
Installation/Location tag mode. Select any sub-options below it depending on
your preferred format for tagging.
5. OK
6. Highlight the drawings in Project Manager you wish to apply the project
settings to.
7. Right-click and select Properties -> Apply Project Defaults.
To apply on a per-drawing basis
1. Open the drawing
2. Select Projects -> Drawing Properties
5. OK
Hope this helps,
Pat Murnen
news:5877486@discussion.autodesk.com...
Mario says:
THANKS
Bill DeShawn
Pat Murnen
Thanks, Pat.
Bill DeShawn
Mario says:
Can you help?
Bill DeShawn
Message 5 of 8
Thanks Pat! That was very generous of you to type all that out!
Bill DeShawn
"Pat Murnen" wrote in message
news:5877758@discussion.autodesk.com...
define this:
5. OK
settings to.
1. Open the drawing
5. OK
Hope this helps,
Pat Murnen
Mario says:
THANKS
Bill DeShawn
Pat Murnen
Thanks, Pat.
Bill DeShawn
Mario says:
Can you help?
Bill DeShawn
Message 6 of 8
No problem. Hope it helps.
Pat Murnen
news:5879683@discussion.autodesk.com...
Bill DeShawn
define this:
5. OK
settings to.
1. Open the drawing
5. OK
Hope this helps,
Pat Murnen
Mario says:
THANKS
Bill DeShawn
Pat Murnen
Thanks, Pat.
Bill DeShawn
Mario says:
Can you help?
Bill DeShawn
Message 7 of 8
Mario says:
Thanks for your great help.You solved my problem. I also had to alter the
Schematic Icon Menu File from ACE_JIC_MENU.DAT to ACE_IEC_MENU.DAT (After
step 4 from the first block of hints). Kindly express my big thanks to Mr P
Murnen and thanks also to you too. Please also forward the above note. T H A
N K Y O U
Bill DeShawn
news:5879845@discussion.autodesk.com...
Pat Murnen
Bill DeShawn
define this:
5. OK
settings to.
1. Open the drawing
5. OK
Hope this helps,
Pat Murnen
Mario says:
THANKS
Bill DeShawn
Pat Murnen
Thanks, Pat.
Bill DeShawn
Mario says:
Can you help?
Bill DeShawn
Message 8 of 8
Yes, good point about the menu. I forgot about that. I will log that this
would be a good topic to add in the help.
Pat
news:5880079@discussion.autodesk.com...
Mario says:
N K Y O U
Bill DeShawn
Pat Murnen
Bill DeShawn
define this:
5. OK
settings to.
1. Open the drawing
5. OK
Hope this helps,
Pat Murnen
Mario says:
THANKS
Bill DeShawn
Pat Murnen
Thanks, Pat.
Bill DeShawn
Mario says:
Can you help?
Bill DeShawn
”Boost
