I want to change de location of default_cat in AutoCAD Electrical 12 of a PC.
Can anybody help me?
We have 2 PC's. The location of the default_cat of on one PC 1 is in a network Y:.... the location of the default_cat of the order PC 2 is local C:.... I want to change the location of PC 2. PC 2 should look in Y:....
Where in AutoCAD can I change this?
I'm waiting,
Greetings,
M. Abbink.
You'd probably have better luck posting your question on one of the AutoCAD boards. This discussion group is for Inventor, and although many people here also use AutoCAD, I think you'll get better results at one of the AutoCAD groups - in this case, it would probably be best to use the specific one for AutoCAD Electrical.
Ok. So the .mdb file is a single file that is named <project>_cat.mdb or default_cat.mdb. If the project-specific.mdb file is used, it must be in the same subdirectory as the <project>.wdp file is located. Here is the AutoCAD Electrical search sequence:
You need to delete (or rename) all this files. Open Options in ACE and choose tab Files. Add there your path to the default_cat.mdb from disc Y.
But there is an easier way. Just place default_cat.mdb to disc Y and set this catalog as second catalog in progect settings. So you'll use standart catalog + your catalog at the same time.
And there is a perfect article about wd.env file where there is a line:
* Catalog Parts Database Path
WD_CAT,%WD_DIR%/catalogs/,AE catalog file path
This is the location of the following databases. These should be shared between all users.
I took it from this very useful blog: http://myacade.blogspot.com/2013/02/breaking-wdenv-file-down-line-by-line.html#more
Please pay attention to it.
And here's a link about your problem http://www.m2t.com/blog/tips-and-tricks/autocad-electrical-2013-cannot-get-the-wdenv-file-to-share-t... too.
