Well, I could still not duplicate it but I did notice something. On the
Bill of Material Check dialog graphic you posted, there is no path to the
database listed in the dialog title as there is on mine seen in attachment.
This could mean 2 things:
1) The Catalog Check is for some reason unable to find the defect_cat.mdb
file. Do you have an alternate catalog database set up for your Acade or is
your database located on a network drive?
2) The catalog number listed in the Edit dialog can not be found when the
Catalog Check is ran. I duplicated your issue by adding a space to the end
of the catalog number in the Terminals dialog and then hit the Catalog Check
button. It tried to find an exact match in the database, '1532050000 '
(space as last character in catalog number), and could not, so the Bill of
Material Check dialog listed only what it knew, the manufacture and the
catalog number. It did not list the path to the database in the title, and
it did not list the Table in the database the record was found in. So you
might check for either a space in the catalog number in the Terminals dialog
and also check for a space in the record in the database.
If there are no leading or trailing spaces in either of these, let me know
and I will try and think of something else that might cause this.
Steve
wrote in message news:4962927@discussion.autodesk.com...
I forgot one attachment.
