Did you open the default_cat.mdb file with a copy of Microsoft access? If
so,
1) Select a table (ex: the "PB" table)
2) Select "Design" (probably the 2nd toolbar icon in the table selection
subdialog)
3) You'll get a table listing the field names in the table. Highlight a
field and check the "Field Size" value in the bottom part of the subdialog.
Change from 60 to whatever you're thinking that you need.
4) Exit
5) Test
If you don't have Access, let me know what fields in what tables you want to
be wider. I'll send you a test mdb.
Nate.
wrote in message news:4852390@discussion.autodesk.com...
No I can't get it to have any more characters than 60 for the description. I
don't know maybe I missed something.
Maybe you could give it a try for me.
