Jim and Steve
The problem here is currently occurring because you have not fully
inserted the footprint yet to create the intelligent link between the two
components. If you make modifications to the footprint at the point as
described, it currently will not trigger a scan or update because the
information has not yet been written to the drawing in the footprint for the
two devices to be considered linked. You must select OK on the dialog to
fully insert the component and then go back and edit it. Thanks Steve for
taking this and logging it for further investigation to see what we can
further do to this feature to ensure the proper information is populated.
For the time being, please finish inserting the footprint from the schematic
list by selecting OK on the INSERT FOOTPRINT dialog and then go back and
make any changes that are needed at that time.
I hope this helps!!
Jared Bunch
Technical Support Specialist
Autodesk, Inc.
"Jim Dowthwaite" wrote in message
news:412b7e30$1_1@newsprd01...
> Steve,
> That sounds like the problem I was having. Hope you can clear this up
> quick, my customer was pretty spooked that his BOM may have incorrect
> info...Nothing scares a controls guy more than the thought of swapping
that
> one digit and incorrectly ordering a $600,000 custom wound motor with no
> possible restock.
> Cheers,
> Jim Dowthwaite
> Applications Engineer
> Solid Caddgroup Inc.
> jdowthwaite@solidcadcam.com
> "Steve Kemp" wrote in message
> news:412b7720_3@newsprd01...
> > Jim,
> > I am seeing something similar to what you describe, but not exactly.
Mine
> > is not updating either value (MFG of catalog). Here is what I am doing.
> > 1 - Insert a schematic pilot light component (LT404) and give it a
catalog
> > data: MFG=ACME, Catalog #=ACME-123R-S
> > 2- Go to a panel drawing, and run the 'Insert Footprint from Schematic
> list'
> > function
> > 3- Select the LT404 pilot light in the 'Schematic Components' list and
> > select 'Insert' to insert the footprint
> > 4- On the 'Footprint' dialog, the catalog data was still MFG=ACME,
Catalog
> > #=ACME-123R-S, so I selected the 'Catalog Lookup' button and selected
the
> > catalog data MFG=AB, Catalog #=800H-PR16R, and selected OK to insert the
> > footprint
> > 5 - It placed the footprint for the AB catalog number, but it did not
> update
> > the related schematic component to this new catalog data information.
> > If I placed the footprint using the old ACME catalog data and then
edited
> > this footprint and change the catalog number to the AB part, then it
> > correctly updated the schematic component.
> > Could this have been what you seen?
> > I am logging this issue.
> > Steve
> > news:412b46b9$1_1@newsprd01...
> > > Steve,
> > > I know I was giving a training course using the ACADE AOTC and had
just
> > > finished the "create new catalogue entry with subassembly" portion.
We
> > were
> > > moving into smart panel creation and I noticed that I had not changed
> the
> > > component catalogue info from ACME back to AB. I selected the AB
light
> > from
> > > the catalogue and did the full scan/update. I added another component
> to
> > > the panel drawing, then went back to the schematic drawing to show my
> > > students the updates and noticed that the mfr was still ACME but the
> part
> > > number was the A part number.
> > > Hope this helps.
> > > Jim Dowthwaite
> > > news:41264e34$1_3@newsprd01...
> > > > Jim,
> > > > I have tried to reproduce this issue and have been unsuccessful.
> Could
> > > you
> > > > give me some more information on the steps that you take to get this
> > > issue.
> > > > Does this happen in all situations, or only occasionally?
> > > > Did you enter or change any other information in the 'Catalog Data'
> > > section
> > > > of the dialog other then Catalog number and manufacture?
> > > > Here is what I did:
> > > > I inserted a Pushbutton on the schematic (Allen Bradley part
number).
> I
> > > > then changed to a panel drawing and inserted this pushbuttons
> footprint.
> > > I
> > > > then edited the footprint, and change the catalog number to an Eaton
> > part
> > > > number. It then scanned the project and updated the electrical
> > component
> > > on
> > > > another drawing with the correct Eaton manufacture name and catalog
> > > number.
> > > > Steve
> > > > AutoCAD Electrical QA
> > > > Autodesk
> > > > news:412610bb$1_3@newsprd01...
> > > > > I've had an issue where I update a panel footprint's catalogue
info
> > and
> > > > when
> > > > > I surf to the schematic symbol the catalogue info does not match.
> The
> > > > > catalogue number had updated but the manufacturer was the original
> > > entry.
> > > > > Has anyone else encountered this problem?
> > > > > Jim Dowthwaite
