Did you insert this table into this drawing using the " insert spreadsheet data to table" command? If so, you need to set up your horizontal and vertical margins in "table style" under the format menu before you use that command. Some, but not all of the parameters from the table style are used by this command. Also, I see that you had the standard table style as current. The " insert spreadsheet data to table" command seems to only care about the parameters in the ace_table_1 style, or this has been my experience, so when you set up the table style, be sure to use this one. I went into the table style setup for ace_table_1 and set the text size, and margins to be the same as what your table actually had. I then went and selected the table and right clicked and then clicked on "remove all property overrides" after I did this, I was able to manipulate all of the columns at will. Of course I had to go back and change the color of the text, no big deal. When the " insert spreadsheet data to table" command is used, property overrides from ACADE are installed with that table. I can't see what they would have been because you didn't include the spreadsheet that this table came from. This command is really screwed up, but it is usable if you do everything just right. I have attached the modified drawing for you to see. If you could post the spreadsheet, it might be easier to see what's going on.
