Hi John,
I must have misunderstood your original post. This set of parameters is used
for defining the wire annotation format that can be pulled from schematics
and written to the panel footprint representations. It's not part of a wire
number format.
The command that uses this format is on the Panel toolbar, the 6th toolbar
button from the left, "Wire Annotation of Panel Footprints". So, if panel
footprint has a wire connection that is actually marked as a cable conductor
on the schematic, you can show the cable tag and color code on the
annotation that can be deposited on to the panel footprint.
Where exactly did you want to show cable tag-ID and conductor/core color
assignment? In the wire number itself or in some report?
Nate.
wrote in message news:5145825@discussion.autodesk.com...
Nate,
This looks interesting. Where do I put the %E and %J parameters? Not the
wire number format. Are these added to the terminal or component footprint
in some way?
Please explain.
John
