Rev 2014
I'm working on someone else's project
on a single page there is 6 cables I do an electrical audit 4 parent cable markers give a Component No connection error its clearly connected
if I delete the cable that gives an error and re insert the cable the error clears this is OK for a single cable but I have at least 200 cables to check and clear this error
any ideas what's happening and does anybody know a simpler way of removing this error
( I'm working towards a wiring list and need to clear wire related errors before I start to generate my wiring lists )
Cheers
Could you post an example of an offending drawing for examination? That would help diagnose the problem.
Have you tried to rebuild the projects scratch database?
AEREBUILDALL command
Also, as Joe writes, posting a drawing with the problem on it makes diagnosing much easier.
