AutoCAD Electrical Forum
Cable Marker Parent Error
2 REPLIES 2
ccad2509
326 Views, 2 Replies
Rev 2014
I'm working on someone else's project
on a single page there is 6 cables  I do an electrical audit 4 parent cable markers give a Component No connection error its clearly connected
if I delete the cable that gives an error and re insert the cable the error clears this is OK for a single cable but I have at least 200 cables to check and clear this error
any ideas what's happening and does anybody know a simpler way of removing this error
( I'm working towards a wiring list and need to clear wire related errors before I start to generate my wiring lists )
Cheers
2 REPLIES 2
drathak
in reply to: ccad2509
Could you post an example of an offending drawing for examination?  That would help diagnose the problem.
Joe Weaver
Principle Associate Engineer - Nashville Electric Service
P&C Committee Chair – SDS Industry Consortium
rhesusminus
Have you tried to rebuild the projects scratch database?
AEREBUILDALL command
Also, as Joe writes, posting a drawing with the problem on it makes diagnosing much easier.
Trond Hasse Lie
AutoCAD Electrical and EPLAN expert
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
”Boost
