I was able to reproduce this problem as you describe in AcadE 2006. I wasn't
able to reproduce it in AcadE 2007, so the good news is that it appears
fixed. Let me know if you need any help applying the menu change to reset
the variable while you are still using 2006.
Pat Murnen
wrote in message news:5151895@discussion.autodesk.com...
Upon further investigation, it seems that this problem happens when a Panel
symbol is inserted, that uses the feature:"Auto-attribute add to footprint
during insertion" (Help documentation from ACADE 2004, Chapter 13). The
invalid INSNAME value is "*C:\program
files\AC2004e\libs\SI_LIB\panel\wd_ptag_addattr_comp.dwg".
