Hello All,
I am trying to add multiple part numbers through the catalog lookup.
I insert a symbol and the edit the component and do the lookup. On the catalog number I select I have a textvalue with CAT01=ABC;MFG01=XYZ
The symbol has the CAT01 and MFG01 attributes and the part numbers are in the catalog.
I though this has worked in the past to add the multiple part numbers to the symbol but it is not working now.
I know i had to exit the edit symbol and go back into it to see it.
I can manually go in and add these parts under the Multiple catalog lookup but we use the same parts over n over and this is a quick way to add the additional parts with little effort.
Anyone have any ideas as to what I am doing wrong???
Dennis
Try changing the part number to a differnt part number and then come back to this one.
The script may not run if it sees the proper catalog number already in place.
So does what I am doing look correct?
I tried changing the part # back n forth with no luck.
I have also tried both of the following:
Deleting the symbol, purging the drawing, reinserting the symbol then assigning the cat# with no success.
Opening a new drawing, inserting the symbol, assigning the cat # with no success either.
The last time I used this was with AcadE 2012 and I am now using AcadE 2014 if that makes a difference.
Any other ideas anyone???
Dennis
The format is correct in the database.
Post a dwg with the block in question and I'll give it a try on my 2014
HERE IT IS.
The catalog # textvalue is
CAT01=MCBH-00;MFG01=ABB;CAT02=MCB-01;MFG02=ABB;CAT03=MCB-10;MFG03=ABB
Dennis
Sorry I just assumed there was something screwy with your attributes. I should have done my own test first.
These attribute names seem to be ignored by the TEXTVALUE field. Rename them to ##CAT and ##MFG and the push works ok. This seems like a limitation. Other than using the ASSEMBLYCODE I don’t have a quick answer. No matter what I come up with, it will be a workaround because TEXTVALUE does not seem to push to the multi catalog attributes.
