Hello All,
I am trying to figure out how to add multiple catalog numbers when inserting a component. I know i can add them manually but is there a way to add them when I do a catalog look up.
In the end I am looking for the BOM on the panel layout to include all the necessary parts i need
I am trying to load a disconnect that has 3 parts
1) disconnect (ab part # 1494V-DS200)
2) fuse clip (AB part # 1401-N45)
3) Lug kit (AB Part # 1494R-N3)
Any insite into this would be greatly appreaciated
Dennis
Solved by testsubject. Go to Solution.
Justin
I am sorry that it has taken so long to figure this out. The software still needs one more attribute to be added to your block.
For each multiple item in the symbol, add a WDBLKNAM## attribute. Set this default value to the database Table where the multiple item data is located. Now when you insert the symbol, the software will know where to look for the part data. I had this problem earlier and this was how I fixed it. I am sorry I did not recognize earlier what problem you were having. The light bulb just when on….
Hello Doug,
I was playing around with your method but I was wondering how you annotate the mulitple catalogs once the Footprint is layed down and the BOM shows that they are correctly linking??
Thanks!
If you mean how do you change any of them, just edit the footprint and click Multiple Catalog. Click the arrow at the top of the dialog to select which entry you wish to change. If you mean assigning item numbers, you can enter manually on the same Multiple Catalog dialog or use my preferred method, the Resequence Item Numbers utility. This utility will assign item numbers alphabetically according to manufacturer.
