Hello All,
I am trying to figure out how to add multiple catalog numbers when inserting a component. I know i can add them manually but is there a way to add them when I do a catalog look up.
In the end I am looking for the BOM on the panel layout to include all the necessary parts i need
I am trying to load a disconnect that has 3 parts
1) disconnect (ab part # 1494V-DS200)
2) fuse clip (AB part # 1401-N45)
3) Lug kit (AB Part # 1494R-N3)
Any insite into this would be greatly appreaciated
Dennis
Solved by testsubject. Go to Solution.
Edit the catalog listing for the main component that you will be looking up.
In the edit dialog box there should be TWO boxes. One will be marked ASSEMBLYCODE and the second will be marked ASSEMBLYLIST.
In the Assemblycode box, insert a code of your choice and click on OK.
Now edit the secondry component listing and place the same code in the Assemblylist box and click OK. NOTE this code must be an EXACT match to the one in the Assemblycode box.
Repeat this for each additional secondry component required.
You can also use this code in another main component and it will call these same secondry components. This means that if you have 5 Disconnectors with different ratings/handles, that use the same secondry components then all you need is the one code and each will add those same components when you add them to the dwg.
Finally, if your components already have the main catalog loaded, you will need to use the command to force an update to your components catalog information. If you have added the secondry components via the manual Multiple Catalog information, you will need to remove this...
Regards Brad
Brad Coleman, Electrical Draftsman
Thanks for your relply but I am miising something.
Here are the steps i THINK i need to do
1) Insert compoment (3 phase disconnect) on schematic
2) under catalog data pick lookup
3) Find part # (1494V-DS200)
4) edit part (under assemblycode) (123)
5) hit OK
6) while still in the parts catalog find 2nd parts(1401-N45)
7) Edit part (under assemblylist) (123)
😎 click OK
9) do same for next parts as needed
so now in the catalog i have the following
catalog mfg descr assemblycode assemblylist
1494V-DS200 AB BLAH 123
1401-N45 AB BLAH 123
1494R-N3 AB BLAH 123
Would this be correct???
It doesn't seem to work
When I ballon the part in the layout it only comes back as 1 part... the 1494V-DS200
I have tried restarting ACADE with no luck. the parts are still in the catalog.
Dennis
My bad!!!
Your description work like I asked (careful of what you ask for you might just get it)
Now the issue is how can i make it so when I balloon the panel layout it shows seperate balloons for each part?
is this possible without putting in each part under the multiple catalog numbers button?
Thanks again for your help
Dennis,
Sorry to be the bearer of bad tidings but that is not possible.
From the ACE Help.
Item numbers cannot be assigned to part numbers based on ASSYCODE combinations.
I use the Multiple Catalog button to add sub parts to a main part.
The way to do this automatically requires a little bit of work, but when set up, it goes very smoothly.
You will need to add the appropriate attributes for the Multiple part CAT and MFG data to each symbol that you want to insert.
Each of these values match up with the Multiple list pulldown: MFG01, CAT01 for Part 1, MFG02, CAT02 for part 2, etc…
Then you have to go into the database and add the appropriate info to the TEXTVALUE Field.
This is what I have entered for my 3-level terminal block.
MFG01=WAGO;CAT01=2002-131;MFG02=WAGO;CAT02=793-5501;CNT02=3
After all this is done, when you do a catalog lookup, the multiple catalog information will be automatically inserted. I discovered that it does not show up right away. You have to close the dialog box first and then choose Edit again to see the updated Multiple Catalog info.
Bob,
Thanks for the help.
This will work good for our application.
It is a bit to setup as you stated but will pay off in the end.
I like to embed subassembly parts in my footprint symbols. Just add attributes named MFG01 and CAT01, MFG02 and CAT02, MFG03 and CAT 03, etc. Fill their default value with manufacturer name and catalog number respectively. The BOM generator will detect them automatically. If you have the project properties set to assign item numbers on a per part basis the item number resequence utility can assign a unique item number to each subassembly part. These parts will appear as Multiple Catalog entries when you Edit the footprint, just as if you had looked them up one at a time.
I added the MFG01 and CAT01 attrribute but the BOM generator/Catalog Check is NOT detecting it automatically as you said.
I've been trying and emailing but no luck....I will appreciate any guidance.
Hi Justin,
I didn't read the rest of the other posts so this may have already been mentioned.
Try adding the MFG01 and CAT01 to the WDA (user attibtues) file so it is availble in the reports.
James Alger
James,
If I create the WDA and click the Catalog Check will it show everything? Thx
Hi Justin,
As far as I know, It will not show up in the "catalog check", It will only show up in reports.
James Alger
Yes, the values exactly matches what I have in the secondary database.
When I click on Multiple Catalog I can see the NFG & CAT attribute BUT when I click on catalog check only the MFG & CAT DESCRIPTION FIELD IS FILLED. THE MFG01 & CAT01 etc DESCRIPTION FIELD is empty.
Please advise what I am doing wrong here.Thanks
Creating a WDA file will populate a MFG and MFG01 field in the report which I don't want.
I thought this was easy but I guess wrong or maybe this software does not have that capablity.
Justin,
If you can, can you post one of the footprint symbols that you are trying to add the Multiple catalog values to?
If the MFG## and CAT## attributes have something in themas default values and the values exist in your default. mdb, then they should show up when you click on Catalog check from within the Multiple Bill of Material Information Dialog Box.
When I insert components by clicking on the the mulitple catalog I can see everything from Catalog Check.
These components(in this case) are in the secondary catalog only.
I created a block, added the MFG01 & CAT01 attributes with their respective default values. I check the secondary catalog database and the values exact. When I insert the block I get just the master component values.
Do I need to do anything with any database? I just can't get it to work.
I am using 2013 version. I am inserting the symbols from a QUICKPICK LIST. My QUICKPICK LIST has only the master data. I am adding attributes to the symbol. I click on the Catalog Check after I've inserted the symbol to my schematic. When I click on Multiple Catalog I can see the MFG01 & CAT01 info BUT THEIR PARTS LOOKUP TABLE IS BLANK. Is this how it is suppose to be? The QUICKPICK LIST has only the master part number.
