AcadE already has the ability to document cables in the from/to list or a separate cable list. Use the cable marker symbols to designate the cable conductors. One you insert the first marker you are prompted to associate additional conductors into the same cable. You can even Lookup the part number when you insert the first marker and have it load the available colors for that particular cable. Of course you can type in the colors if you need. When you generate your from to list or cable list you can add the appropriate fields to show the cable tag, cable MFG, cable CAT, and individual colors within the cable. I have attached a screen shot as an example.
Edited by: dougmcalexander on May 21, 2009 6:10 PM
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in
AutoCAD Electrical training and implementation support
Phone and
Web-based Support Plans AvailablePhone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please
Accept as Solution if I helped you.
Likes are also much appreciated.
