AutoCAD Electrical Forum
Ballon size
2 REPLIES 2
jdonaldson3
369 Views, 2 Replies
Ballon size
What variable controls the ballon size when using the wd_balloon coomand?
Sorry using ACADE 2008
TIA
Jim
2 REPLIES 2
OP21
in reply to: jdonaldson3
Panel ribbon
  • Configuration
  • Balloon setup
  • Balloon Diameter
This should help...
Omar
Hope this helps!
Omar
P.S. If this did help you, remember to "Accept as Solution", so the answer can help others. "LIKES" are always welcomed and much appreciated! Thank-you.
jdonaldson3
in reply to: OP21
Omar
Thnaks foir the help. For those of us still using pre ribbon versions look under Panel Configuration.
Jim
”Boost
