Is this a utility that creates a file containing the "zipped" files or is it
just a utility that compresses (i.e. compacts) files "in place". If you drop
down to the DOS window and type "compact /?" [Enter], you get the list of
command line parameters. But I don't see one that allows the selected files
to be output to a unique file name. It seems to be that these files are
"compacted" in place. Donno...
wrote in message
news:5721173@discussion.autodesk.com...
Thanks Pat, but Im a step ahead of that. Windows XP has a built in program
called compact.exe. When I do like you said and enter its path after the
wd_zip, it doesn't zip the files correctly. My IT guy says I need to enter
in some sort of special command prompt but the ones that I tried dont wont.
I tried this for my wd_zip, line:
C:\windows\system32\compact.exe -and-
C:\windows\system32\compact.exe c/
I was hoping somebody else knew how to get this program running with the
wd_zip command since its free.
