There are two types of BOM reports (Schematic and Panel) in Autocad Electrical 2012, you can go to Reports tab in Ribbon, if you want to generate Schematic BOM report, then click Reports button under Schematic panel, otherwire click Reports button under Panel panel, then select BOM report name and follows the wizard to generate it.
Kevin Li
Thanks for sharing this info! I just downloaded the 30-day trial and this software is amazing. Can you recommend any books I could buy for learning AutoCAD Electrical 2012. Thank you!
Go to Help in your 30 day trial version, especially on the Tutorials. Also you can find a pdf file in the Help folder in your install path in your disk, it is Autocad Electrical 2012 user guide, you can learn from them.
Kevin Li
